RF T1's vs w3 vs l7
Brandon210
Ok so I just bought 2 12" RF t1's I'm just hoping I made a good choice over the w3 and l7 they were all the same price, also wanted to know if my amp and box was big enough
2 12" RF T1's
Amp: Alpine 1005D
Box 16"high 20" deep 41"wide
Thanks and all honesty and criticism in apperciated
If you have 2 Dual 4 ohm subs then you can't wire both down to 2 ohm, so yes, either get a matching amp or one that does 1k @ 1 ohm. I vote just get one amp that does 1k @ 1ohm because you don't have to mess with gain matching and what not. I don't know what you consider "major bump" but you should be around 140 with this.
^once again... this....
l7's can definately get louder... under the right conditions... but then again... thats under the right conditions. you get the set up wrong, and you'll be dissapointed.
T1's on the other hand, dont require AS much specific parameters (box size, power) to get nice and loud
2000 suburban all I know about the box is what's posted above and the electrical is 120a alt and upgrading battery
---------- Post added at 05:27 PM ---------- Previous post was at 05:26 PM ----------
And can u recommend a amp for the set up
Brandon210
Brandon210
San Antonio,TX
Brandon210
