RF subs (pls read!!)
Wonderbread
Against Avatar Theft
all right i ahve 2x8" RF punch XLC subs specs are as follows:
All XLC Series Subwoofers Include:
Dual Laminated Foam Surround
Hyper-Extended Pole Piece
Magnet Bumper
Aluminum Former
Spruce Pulp Paper Cone
Aero Vent Base Plate
Dual Laminated/Progressive Flat Spider
XLC Series RFP-2408 Subwoofers Include:
8" "Punch XLC" Mobile Subwoofer
Single Voice Coil
Power Handling: 200W (RMS) 400W (max)
Nominal Impedance: 4 ohms
Sensitivity: 85dB
They are right now hooked up to a Hifonics Zeus z400 Amp, running great, i belive at 2 ohms
I also have 1x 12" RF Punch Power DVC sub, currently ampless....
The specs for this is as follows :
Impedance 4 ohms x 2
RMS / Peak Power 1000 / 2000 Watts
Sensitivity 87dB
FS (Hz) 24
The question is - can i/ should i wire this 12 up at 2 ohms with a JBL 1200.1? Will it work?
I have a deck with 2 x 2.2V preouts... I am also planning on adding (very shortly, likely before adding the JBL amp) 6.5" Infinity Reference 605CS components to the front stage. Looks like i'll be splitting one preout between the two sub amps and using the other one for the seperates, amke sense? any reccomendations on the wiring? thanks
hi
i also have a 12" RF Punch Power DVC sub, it is wired at 2 ohms. you have 2 options to wire this sub 2 ohms or 8 ohms . take your pick, either is fine acording to rockford.
mykeys, how the heck do you think im gonna blow a 2000Watt peak, 1000 Watt RMS DVC sub with a 1200 W amp?!
That JBL isnt rated to much higher than 1300 Watts RMS, at 2 ohms.
Also, isnt Rockford known to underrate, especially in years gone by, seeing as this is a 2000 model year sub, shouldnt i be fine? dont worry, i wonbt be playing 'volume master', i'll be keeping the gains down, and such.
The JBL1200.1 is JUST FOR THE 12" PUNCH POWER DVC
Sorry man....I am having a real problem with skimming today.. I saw the 200 watt 8 and skimmed the rest..I am gonna have to pay better attention or sped time in the corner not playing on the cpu..//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
Mike
If you are planning on getting components and a seperate amps, I'd get yourself an external crossover/equalizer, most of them have 2 inputs and 3 outputs with a seperate output for your sub, worthwhile investment rather than splitting preamp outputs
Keep it loud!
JELLYDIME
ok, i now ahve the 2 8's running like b4, the 12 is still ampless, for alittlw hile longer also, and i have bought and installed Infinity Reference 605CS 6.5 Comps, and in the next week or so, i think i'll be getting some infinity reference 6*9's too.
they have no amp yet and are still running off the deck.
as will the new set be.
ANYWAYS, i forgive you mykeys :p lol and would like to know how muhc those external xovers/equalizers run? is it worth it to invest, or should io just forget that and wait till i get my new deck?
xovers and equalizers run anywhere from $60 for a cheap on to $300-$400 for a really really good one...I run an MTX ($120) and it has worked very good for me for almost a year now. It helps with the preout problem and makes it MUCH easier to shape and control the staging and sound of your stereo.
Keep it loud!
JELLYDIME
Wonderbread
Wonderbread
Vancouver BC
jellydime
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
