RF sub secure on box
  • 4
They have 8 screw holes, right? If that's the case, I would just add 4 more screws to each sub to make sure it's secure. You never wanna use real "glue", but sometimes with bigger subs you can use silicon while screwing it down to make sure you don't have any air leaks. In your case, I don't think you'll be running enough power to really worry about alot of leaking. Good luck
Originally posted by violator5spd They have 8 screw holes, right? If that's the case, I would just add 4 more screws to each sub to make sure it's secure. You never wanna use real "glue", but sometimes with bigger subs you can use silicon while screwing it down to make sure you don't have any air leaks. In your case, I don't think you'll be running enough power to really worry about alot of leaking. Good luck
Hmm, won't the silicone cause rust to the speaker brace? I know they SAY it's coated with a lot of stuff, but I accidentally dripped a wee-bit of silicone on mine and after trying to remove the hardened silicone, the paint came right off too... I dont' think it's cheap paint either..it was a rockford...
And about weather-stripping...is that stuff about the same as those that cushions a PC mainboard and other PC peripherals? You kow, those black spongy things... I've got a LOT of those in the office, and from the pictures that I've seen, it looks pretty much the same...
Hello all, been gone a while but hoping to get some help. I have a 2024 Tesla Model Y and am trying to decide between putting a single 10" sub...
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
53
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
510
drpain714
drpain714
San Jose, CA
paikiah
Doxquzme
    Apr 28, 2024
Doxquzme
    Apr 28, 2024
Latest topics
