I used them for a little under 3 weeks. Reason why i'm selling them is my Solobarics finally made it back from kicker. If it makes a difference I did purchase these from an Authorized RF dealer and I have the paperwork for it.
Oh yeah its a Pair of 12" Punch hx2 Duel 2ohm
Here are the specs:
12 inch
Type Woofer
Voice coil Configuration - Dual
Material - Aluminum
Description -
3 4-Layer
Cone Material Paper -
FIBERlock
Frame Material Frame - Cast
Material - Aluminum
Surround Material Rubber
Description -
Santoprene BART
Spider
Crossover
Specifications Power handling(RMS) - 500 Watts
Power handling(Peak) - 1000 Watts
Impedance - 2 Ohms
Sensitivity - 86.7 db
Vas - 2.86
Fs - 25
Qts - .407
Xmax - .55
Dimensions Depth Bottom mount - 5.1875 in.
Cutout - 10.8125 in.
Displacement - 362.88 cu in.
Enclosure Sealed box -
Recommended Minimum Volume (Cubic feet) - .8
Recommended Maximum Volume (Cubic feet) - 4.0
Ported box -
Recommended Volume (Cubic feet) - 2.0
F3(Hz) - 35
Number of Ports - 1
Port diameter(Inches) - 4
Port Length(Inches) - 10.75
I really need to get rid of these and I need the cash for my new subs so $215 for both //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Here are the specs:
12 inch
Type Woofer
Material - Aluminum
Description -
3 4-Layer
FIBERlock
Material - Aluminum
Description -
Santoprene BART
Spider
Crossover
Impedance - 2 Ohms
Vas - 2.86
Fs - 25
Qts - .407
Xmax - .55
Ported box -
F3(Hz) - 35
Number of Ports - 1
