RF Power 800.2 enough power?
It'll do more power than the 500/1 but whether or not it'll be "enough" is dependent on you.
Going by the ratings, you'll get an extra 300 watts, which will turn into greater output, though at what amount I'm unsure. It'll probably louder, but to what extent you'd have to try it and find out.
Maybe I should just sell my 500/1 and take the money I was going to spend on the 800.2 and get something with some head room.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
This setup used to pwn in my high school //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif Realistically I would look for something a bit bigger than the powerbass or Rockford. 1500 watts would be nice on the pair
How about something like a HIFONICS BXi1606D?
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
533
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
394
806
WashYourWinky
The Pilot
WashYourWinky
Cincinnati, Ohio
WashYourWinky
    May 12, 2024
Brendon Jenness
    May 11, 2024
