RF amp overheating
soldiermedic
Noob4Life
I have a T400-2 powering my single Infinity DVQ 10". Current RMS is 512 watts RMS at 4 ohms bridged...I have it wired for 2 ohms. Problem is that at moderate volume (being heard from about 100 feet away), I can only play it for about 1.5-2 hours before it gets hot. It's not the space, there's open air to the top and 2 sides. Any suggestions, and has anyone else had an issue like this?
Isn't the t400 a class A/B amp? I wouldn't be surprised that it gets hot.
If you'd like, you can wire up a fan to cool it. Active airflow over the amp's heatsink makes a massive difference. I did this in my car to help cool my amps; It's quite easy.
Radio shack sells 4 inch 12v cooling fans, or you can find your own fan - the main point is that you need to wire a relay to your remote wire from your deck, then wire your amp's turn-on and the 12v fan to the relay's output. This can be nice to do anyway if you are turning on many devices at once with your deck (say, 3 amps, multiple crossovers/EQ's, etc)... but it's necessary in this case because your remote wire can't provide enough power to power the fan.
When the deck turns on, it switches the relay on which connects the 12v power to your amp's turn-on and the fan itself.
Fan:
http://www.radioshack.com/product/index.jsp?productId=2102823
Relay:
http://www.radioshack.com/product/index.jsp?productId=2062477
i am just guessing so check your manual
but
i am fairly sure that this might be your problem
RF ab amp
2 ch
run it as a 2 ch at 2 or 4 ohm okay
bridge it at 4 ohm okay
bridge it a 2 ohm and the load is not gonna work right hence your over heating
check your manual to confirm what i am saying
I have it bridged at 2 ohms. I was thinking about bridging at 4 ohms and seeing if that makes a difference in sound. I just want to make sure I cover the RMS of the sub, which is 400 watts.
Your amp will run cooler at 4 ohm but you will lose power output by half. The only way it will change the sound is by losing 3db. But if it's 1 ohm stable bridged then I would leave it at a 2 ohm load.
Crap! I can't rewire the sub for 4 ohms, I can only wire it for 8 ohms because it's a dual 4. ME RETARD!!!! So, any other ideas besides buying another D 4, getting a single 4 or getting a D-class mono?? LOL!
soldiermedic
Noob4Life
soldiermedic
San Antonio, Texas
headless
