RF 800a2 with Alpine Type X
07ramjam
I came across a deal on this amp that might be too good to pass up but Im not sure if it will work or not.Heres my question.
I can wire my sub at 2 or 8 ohms.Can I wire it 2 ohm and run the RF bridged?If so what would the final load be on the amp?
BTW,I might be getting thi amp for 125.00.I did some research and that seems pretty fair.Would you all agree?
Thanks
if you wire the sub to 2 ohms, the final load is 2 ohms //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
i'm not looking up the specs on the amp, but if it's 2 ohm stable and you get 1k out of it (that sub needs it) then $125 seems decent.
Amp is 2 channel, only way you going to get 2 ohm safely from it from you sub is if you have a Dual 2 Type X. If you had the Dual 4, you could wiring them in parallel and bridged the amp, but I would not recommended it.
the sub only comes D4 //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
07ramjam
07ramjam
Temecula Ca.
jco1385
vegang
vegang
