REVs VS RSDs
I have rev 6.5 comp set running off 75w rms and they really crank and sound good while doing it. For the money they are really hard to beat. You may have to play with the tweeter a bit, i found it a little harsh at times.
i was planning on getting the RSD's myself .. and seeing how they sound .. since they are only 100$ .. i could go with some infiniti Kappa's .. but those tweeters are big and shiny
the rsd's will need a minimum of 150 clean watts per side. i have heard that the revs don't need quite as much but i cannot confirm this as i have never used them.
I do not believe this...speakers rated at 60rms and 120peak do not need 150rms to sound good.
A minimum of 150RMS? Are you crazy? I would say that is nearing their upper limit!
75RMS is plenty for those. Will more power help them out? Sure it will. But their MINIMUM is weeeeeeeell below 150.....somewhere around 50RMS
RSd's- try to get an amp that will provide them a clean 2x100-150w rms.
REV's- try to get an amp that will provide them a clean 2x50-100w rms.
A brand new 2x150w rms CA600 amp at $69 factory direct would be a great choice for either, imo.
Agreed. Profile makes some of the most affordable stuff out there that isn't garbage. I had an AP2000 powering two sealed CVR's and they got loud.
moorezy
moorezy
St. Catharines, ON, Canada
tcguy85
