Reverse Mount Question
AlpineAudio
Right now i have 1 Alpine type X in a 13.5"x 15.5"x 20" Vented. I went by Alpines specifications. Should i try the reverse mount? Would it make that much of a difference with magnet out?
thanks for any hely //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
it'll make the box think it's bigger.
It will actually make the box bigger, boxes don't think. You are adding the volume that the sub takes up to the net box volume.
Why do you want to inverse mount it? Just for the hell of it? I doubt it will make much difference.
inverted subs went out in the 90's when they realized it didnt do anything to enhance sound, it just looks cool as hell //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It will increase the net volume and lower your tuning ever so slightly. Make sure you hook up the negative lead to the positive terminal on your woofer and vice versa with the other terminal so that the subwoofer still moves the same direction when playing since it is inverted.
aint that what i said? in a much breifer way? lol:D:D:D
try reversing the polaritywhen you invert the sub
AlpineAudio
AlpineAudio
Minnesota
dappa5
