retarded math question.
area= ???^2
multiplying 2 numbers (w x h)= area
volume=???^3
multiplying 3 numbers (l x w x h)= volume
your port case would be volume.
aww man u guys beat me to it...
so why do they always say square inches of port?
if i need port volume?
well whatever it is... how much port area do i have? someone said
it wasnt enough in my box building thread...
______________________________________________________________
hold the flames... i see that ive got 21.75^2 of port... i guess thats a little small?
Two different things. You need to know port volume simply to know how much airspace the port is displacing within the box. The port area can have a direct effect on performance....too little or too much can be a bad thing.
yea that is a little small. to put things in perspective i got 104 inches^2
but youre running 2 15"s with 2600 watts... that i can understand a lot
of port area for...
im going to be running a 15A with maybe 800-961 watts... ive never had
port noise even with a small round port with any of my setups...
so lets hope...
but youre running 2 15"s with 2600 watts... that i can understand a lotof port area for...
so lets hope...
I am running a total of 6000 watts. 3000 per sub.
But i would say that the are you have is fine. What is you r box volume.
You have an electrical system capable of handling a current draw of (at best) 520A?? That's assuming amplifier efficiency of 75% and a constant 14.4V on the electrical system.
Not always. I got a 200 amp alt, yellow top, and red top. i want to go with dual alts soon. so if anyone can weld me some brackets let me knowa.
squeak, that assumes that he is running 0dB tones at full tilt constantly.
Sheesh... when did you become an alt salesman? //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Sorry, it's just one of those things, a pet peeve I guess; Nobody that I know of has the electrical system to run a true 6000w in a DD.....typically that's just what their amps are rated but they aren't actually pushing anywhere near that amount //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif (yet they don't mention that part)
I could run a 10kw amp in my car. But if I have it setup to put out no more than 2kw, or an electrical system that can't support 10kw worth of output, I shouldn't go around claiming to run 10kw.....just doesn't make sense.
the box dimensions are
16 x 25.5 x 17
with the port in question taking up some
space and the driver once its in...
bbp6 says i get about 2.2^3 net...
holy crap monte... thats a sh1tload of power... are you deaf?
assuming bbp6 and my building skills are at least close...
what do you set a SSF for for a 31hz tuning???
No, I do understand. I'd agree.
It's just one of those things.
your just a hater.
Don't hate the players. Hate the game.
When you coming up to skeps. Then i can show you what PA is all about.
g30ffr3y
soul destroyer
g30ffr3y
buffalo, ny
squeak9798
slater
    Oct 4, 2025
    Oct 4, 2025
