Resistor...answer my question! lol
you probably wont find a resistor large enough to stand up to that...
why not just try running it at 2 ohms and see what your amp does?
Alright I didn't want to take chances of blowing it, but now that I think about it..Won't it go into protect mode instead of frying?
Yea I'm not goin to push my luck, do test tones work in home audio too? If so what test tone should I use..
Also, right now it is in a 2.2 cube @ 32hz enclosure for the time being. How would it sound in 8.55 cubes and tunning _______? (not sure on tunning...I was thinking 25 or 28hz)
low maybe?
I would do about 3.5-4 cubes tuned around 22-24hz.
running a resistor in line is far from a good idea, as it would probably burn up.
most resistors you find are like 10w resistors so you would litereally need 100 of them to be safe enough not to burn up, and even then it wouldn't be effective
if you are dead set on chancing the impedence you should check out a product called Accumatch, it is an impedence matching transformer made by Veritas audio
one of my tru amps caught a "100w" resistor on fire //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
even the big boy resistors are not designed to carry that kind of current for an extended amount of time... this was used in a crossover, and granted that the amp was pushing quite a bit over 100 watts, the thing caught on fire and left holes in my silverados carpet. it would have to be a HUGE resistor for a sub...
i still say your best bet is just to run the amp at 2 ohms and see how it does... with impedance rise you should be fine.
zactly
solidcrowd
solidcrowd
Buffalo, New York
solidcrowd
