resin and hardener...how much?
the amount of hardener you should add is proportionate to the amount of resin your using. it also depends on the temp. of the work room, how quickly you can work with it, and so on. if you add too much at one time, if will being to gell and harden before you can use it all. i usually do about 4-5 oz. of resin with about 1-2 good squirts of hardener. i would suggest just doing a small amount of resin with a small amount of hardener and just basically do a trial and error type experiment.
Aight...that sounds like a good idea
About 10 drops per ounce of resin is a general rule. You can add a few more drops per ounce and make it a little hotter. I usually use 4-5 oz resin at a time with about 50 drops of hardener 60 if I want it to heat up and dry a little faster
Weeznur32
Weeznur32
Seattle
bigbirney420
vegang
vegang
