OP
LOL..it seems..wool does cover ones eyes to the truth at times..lol..Ive been in car audio since 87/88,and have had so many cars and audio systems, and have found ways to make things as easy as possible and get results as achieved.My truck holds 2 agm batts, a 255 amp alt, the big 5,rather than the big 3 done, and 4amps,oga wiring, 4 1000rms tens ported@32hz ea chamber,cdt Briax up front with 5.25 polk bass, and 2 sets of extra tweets, a set of 6.5 cdt components in rear, an eclipse hu, and a kicker kq9 preamp eq..in xcab 98 3dr chevy..the subs are 2.0cuft per chamber @30hz..sounds pretty good, i think..use all old school Autotek BTS,and Mean Machine ampsHAHA true that... We're in Texas though so we got it better than most folks![]()
Ground can be done at the amp to the structure/metal/bolt that goes to the frame..The new amp install kit will/should have a fuse holder that comes with it, that needs to be put at the battery,should be pretty easy to do..and should have instructions to do,as 1,2,3.Run the wiring, and ground that amp, before you put the fuse in of course.You can run a piggyback wire off your existing remote to your new amp also,and will turn on/off as your existing amp does, and save you some time there and shouldnt be an issue,and save some wire alsoYea I'm planning on buying another 8ga amp wiring kit. Same one that is on my current amp. Then I'll follow the original installer's wires. It should be easy!
The only thing I'm worried about is grounding the power wire and installing the inline fuse holder on the power wire. I don't know how to do this...
If its a good ground spot, Id use it..Use a ring terminal and wiring to add..When you use the same ground, be sure to either take the power wire loose at the battery, or fuse out on the existing amp , so you dont have an issue/spark.I use a single ground of 4ga to one spot, and use a solid distro block for multi grounds, like this hereOk so the allen screw is the trick. I got it. Regarding the ground, I haven't done enough investigation as to where the original installer grounded my original amp. If possible, should I ground the new amp at the same spot? Or is that bad to have two ring terminals grounding on the same bolt?
The remote wiring has already been ran to your existing amp from the radio/headunit..it will say remote on the amp,normally next to the Poss/and neg on the amp..wiil say Remote..with the little 18/16ga blue wire in your kit,just cut off some to wire from your Remote on your Existing amp to your new amp..this allows for the on/off of the amplifiers at the turn of the knob of the headunit..Piggy back wiring is what I call it..no need to run another remote wire from the HU to the amp, when you already have it back there at the other amp.//content.invisioncic.com/y282845/emoticons/santa.gif.e1ec9cf2e0a0dd232ad35aa594a126d0.gifOk sounds good. I'll remember to remove the fuse. Regarding the remote wire, what is this for?? I don't think my head unit even has a connection for this. The head unit is a Kenwood KDC-BT752HD
