removing trunk springs
I've thought about it a few times, the best alternative to propping it up is with shocks from snug tops or hoods. They are pretty spensive tho.. probably about $100 after tax and shipping
McMaster-Carr has a wide variety of gas shocks and all sorts of fittings. I've had them in my car for three years with no problem at all. You can pick the exact lifting power you need.
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
680
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
fatboyracing
fatboyracing
Owensboro KY
kurrupt
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
