Removing a Screw With a 'Stripped' Head
lots of ways. depends on what it it. you can drill it out if there is nothing on the other side to mess up. you can use a dremel or grinder also. just make a slot and use a straight screwdriver.
depends ont he screw and where it is located but there are a few ways
either get a dremel and a cut off wheel and cut a slot into the head of the screw to make it accept a flat head screwdriver
get a crafstman screw out set (work really well and arent very expensive)
or drill through the head of the bolt and gte a set of easy outs i think they are called, but they are just a reverse thread hardend screw that digs itself into the hole and removes the screw
they also work fairly well just take more time
169db
169db
birdville
Bender.
