Remote Wire VS Accessory Wire ..Whats the Difference?
Your remote wire is switched by the head unit. The accessory wire is switched with the ignition usually, but I have seen accessory wires that were not switched in random vehicles. Some accessory wires are constant. You need a DMM to probe and see how yours works in your particular vehicle.
Your acc wire is fused and can power several things (radar det, cellphone charger, etc.).
The remote wire is not fused and has extremely low power and should only be used to connect to amps.
both answers correct good job guys this is what I like to see here.
Well I'm powering my Amp with a remote wire from my computer. But my computer also has a ACC wire that needs power, can I power my comp using my spare remote wire that i have ran or do u think i need to have a "real" acc?
Don't get how your computer has a remote wire?
But the answer is No you can't use the remote wire in place of an Acc wire. Your best bet is to use an automotive relay and use your batt wire which would be switched on by the remote.
I have a Carputer built from MO-CO-SO.COM.. . it powers up my amp with a remote from the comp so that windows startup doesnt cause feedback to my speakers....
Kentucky
