Remote wire thickness
dakayus
LA
Ok I was just panicking that my system was dead and I realized I didn't have a remote wire which I think turns on the amp. Anyways, what gauge wire does this need to be? I'm hoping this is just the problem. I also have a tiny piece of wire that i'd guess to be like 20-22 gauge that's on my RCA cables. The remote terminal on the amplifier looks like it should take some 4 or 8 gauge wire.
Thanks guys
The wire on the RCA is for the remote wire. Install a small 1/2 amp inline fuse (less than $1 ) at the back of the head unit, then attach the RCA remote wire to that.
It's only running less than a 1/2 amp of current, but if it shorts out it will damage your head unit. The little fuse protects your head unit.
never heard of the fuse part before.
remotr wire uses miliamps if not picoamps
you will be fine with 20
i use 16 ,i dont like being half way done with an install then i tug on the wire and it rips
happened once,never agian
i think i was using like 26 ga it was really thin
Very few manufacturers actually integrate a remote wire into the RCA's.
Straight to pico?? What about micro and nano. BTW - It's milli -- 10 to about 40mA according to the data at bcae1. They're older amps, but I wouldn't think there's been huge changes in turn on circuts over the past few years.
dakayus
dakayus
LA
ultimate157
