reformatting computer
u can do that just makes sure that it is the EXACT same version as u have so like if u have Win Xp pro w/ sp1 serial u CANNOT install win xp pro.... the serials arent the same.... the serial should be on the back or side of ure computer and find the EXACT version that that sticker says and u can use ure serial with sombody elses cd
//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
Every single CD has its own serial number, not every version has the same serial...
And if you figure out a way to do this, let me know, might come in handy. But as of now, I know of no way to completely wipe the drive back to factory settings without having a back up CD or having a back up drive with that info stored on it.
Incorrect. The serial is merely a license generated with an algorythym. While each license key is unique, no one serial for Windows XP Home Single user will not work with another copy of Windows XP Home Single user.
The exception is, as stated, if the installation has a service pack slipstreamed.
SP1 serials do not work for non-SP images, and vice versa.
Any copy of Windows XP is capable of being
XP Pro, single user / corporate license (no activation)
XP Home,
XP OEM
What dictates that is a file in the root of the CD, the CD's title, and the serial number you enter when installing.
If you need a Windows XP serial, google
"fckgw-rhqq2" (that's all I remember.) It's a corporate license for Windows XP, no service pack.
Google how to burn a bootable windows xp cd, or go download the WindowsXP-6in1 Iso from like ehh. Betasirc.
^ if you use XP to make a boot floppy, or burn a boot cd, or boot to a ramdisk, or network boot, then sure. you can format /y.
fdisk is pretty leet.
kayrad = debug to manually write zeroes to the bootsector, disk and file allocation table.
There's always linux. It's free. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
saywhat?
satx120, jealous?
saywhat?
H'Burg Mississippi!
theCybe
