Red Top Woes (pics)
swangandbang
I bought an optima red top and tried to fit it onto my nissan 2003 altima, but the terminal won't fit onto the post. I need to have about 2.5" of clearance, but I unfortunately have less than 2 inches //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif. Anyone know where I can buy just a longer terminal and replace the terminal in the 3rd pic with it?
well, that looks pretty simple. get a 3 " length of 1/0, unbolt the terminal, install it inbetween the factory wire and the factory terminal. you don't even have to cut anything.
it appears that the female part of that unit will come apart if you remove the nut with the blue stripe on it... get a small length of 1/0 and make a "jumper." The automotive store will probably have adaptors too... This is one of those fun projects when you learn to be a lil more creative. LOL!
get a new battery post and jsut wire the factory wires to that and be done with it.
if the wire isnt long enough trace the wire back to the main fuse block under the hook, its usually attached with a ring terminal there, just make a new wire to go from there to the batter.
do the same with the alt too and be done with it.
you should be doing the alt anyway, and it would only help to make the fuse block a nice 4 guage instead of the usual 8 guage that most cars use
look for some nuts or anything thats holding that eletrical loom down. it should be clipped onto something, well in my car it did. try to look for anything thats holding it back. unplug it and you might be able to extend that wire a couple of inches.
swangandbang
swangandbang
Austin,TX
dleccord
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
