Yung_Chrome
So i've done my research on the RE Audio SX18D4. its says to use 8 cubic feet per sub(only going to use one). but after using a custom built box generator, i don't believe this is going to be able to sit in my 88 crx trunk =S.
Any suggestions? Thank You
btw here are the spec's as quoted from a ebay retailer.
* 18" Competition subwoofer with massively deep sounding bass
* Nothing comes close to an 18" sub with this much power!
* Hand-built in the USA (These are put together with extremely strict ratings and standards. These are known to be one of the best engineered and best quality subs on the market)
* 2 Year Warranty
* 1000 watts RMS Rated! (Note this can handle more than 1,000 watts. It is rated with a stricter standard of power testing, then most other car audio brands)
* Dual Composite 2-piece Cone
* Rubatek Foam Surround
* Cast Aluminum Basket
* Tork-Tite Terminal
* 3 ” 8-layer Aluminum Voice Coil• FEA Optimized Motor Structure
* Triple Stack Magnets
* Progressive Spiders
* Wrap around Rubber Gasket
* 18"
* Mounting Depth - 9.5"
* Mounting Hole Diameter - 16.75"
* Overall Diameter - 18.5"
* Bolt Hole Circle - 17.5"
* Motor Width - 6.5"
* Motor Depth - 3.25"
* Basket Depth - 6.25"
* Displacement - 0.22 cu. ft.
* Weight: 32 lbs.
* Use Ported Box Only!
* Ported box volume: 8.0 cubic feet; tuned @ 34 HZ
* Electrical Q Value -Qes: 0.53
* Mechanical Q Value -Qms: 6.1
* Total Speaker Q Value -Qts: 0.48
* Free Air Resonance -Fs: 33.2 Hz
* Equivalent Compliance -Vas: 159 liters
* One-Way, Linear Excursion -Xmax: 22 mm
* Efficiency -SPL 1W/1m: 92.7 dB SPL
* Effective Piston Area -Sd: 1210 cm^2
* DC Resistance -Re: 1.9 ohm
* Nominal Impedance -Znom: Dual 4 ohm
* Thermal Power Handling -Pe: 1000 W
* Force Factor -Bl: 21
And also the link i used to generate the dimensions
http://www.klausaudio.com/subwoofer-boxes/customize.php?productid=27&categoryid=25&x=11&y=16
* 2 Year Warranty
* 18"
* Weight: 32 lbs.
