Recommend me 6.5 components
What do yall think of hertz mlks?
I'd run those, but they want power. How much you got?
I would bridge a Sundown 100.4 on a pair or there abouts.
Also, if you travel where it goes sub-zero, you may have an issue
with the mlk's (I think it was the mlk's).
Seeing as you used the word crisp when describing sound you may want
to look at the k2p (or the new k-somethings?) as mentioned.
For 650 i'd be looking at rainbow profi's...almost to vanadium cross territory there, or, you can try saving ~300 more and going with some power line cs's if you can accomodate them (they are 96mm/3.8 inches deep and use the same motor/basket as the vanadium 7" subwoofers //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif) - so you don't have to upgrade again... Assuming you have already deadened the **** out of your doors. If you haven't deadened your doors, don't spend 650 on components //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The deadening is coming. Damp pro //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
I'm going to foam in some places as well, like in the rear support bars that are hollow.
Buck
little alien on campus
Buck
Inside of a pyramid
Buck
