recommend a 2-chan that will do my morels justice
//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif ever thought of not smoking so much?
i wasnt complaining, just explaining my financial situation. we all have our priorities.
i have decided to bridge the kicker kx650.4 for the meantime, once my install guy tunes it, im going to (carefully) determine where it clips (for the sake of argument, lets say it is going to clip at volume 23/35 on the HU). then i am going to stay 2 volume levels below the clipping pt., see how it sounds and then go from there. if i decide to get a new 2 chan, i will most certainly be looking at the arc, and i wanna thank u guys again for ur advice.
Better late than never but after doing a couple of installs with the new Eclipse XA series of amp, consider the XA4000 (125w rms X 4( and run it in bridged mode as well. It is a ICEpower full range class D that will give even the best of class AB amps a serious run for their money. Add the known factor of how efficient the B&O design is and it is sure to be a winner in a situation like this. End result is going to be as much or more power than the Kicker and draw far less current, a side benefit here is that the amp is going to be able to run waaaaay cooler and far longer. If you are thinking that you want and need power to get those speakers to sing like they were designed to, you need to consider the ability of the amp to maintain it's "cool factor" which Eclipse has done on both counts. A good looking amp and one of the best designs in the industry.
frankiebones
frankiebones
NYC
forbidden
