No, my argument does not fall apart. In terms of the accuracy of the driver, the Brahma, XXX, or W7 will still be superior. Like I said, at ANY power level.
Now would I say it would necessarily provide the most output for that power level? Not necessarily, but I never made that claim.
You have been attempting to claim that a driver could "sound better" with more power, you failed miserably at that, and now you are trying to claim that a driver which is near it's RMS will sound better than a driver way below it's RMS, but that too is an idiotic, irrational, and poorly reasoned claim.
It's fine if you don't realize your errors, but my arguments are flawless, and they are entirely based upon science, whereas yours are based upon nothing at all.
Remember, the claim being refuted was not "You might be happier with X driver because your power levels are are closer to the maximum of that driver than driver Y." The claim was "Use driver X because it will sound better than driver Y, because driver X is closer to xmax at the power level specified."
You cannot refute the latter claim, which is blatantly false, by attempting to prove the former claim. That is precisely what you are trying to do.
You have no chance of winning this. Give up.
Blah blah blah. Same old warbleed, condescending as ever. I wonder, are you this arrogant in real life? This is why I hate debating you, even on an issue Im genuinely interested in learning about, you make it such an ordeal with your high and mighty 'my facts are indisputable!' attitude and use putting people and their ideas down as a tactic to attempt to 'win' the debate. You really need to change your tune, this one is getting old.
You are boring me at this point, you only want to come back to 'accuracy' in terms of distortion output. My fingers are tired from trying to explain to you that there is more to a driver's 'sound' than simply raw distortion output graphs. Sorry I dont seem to be able to get that point through to you. *shrug*
Again, if what you say were true, RE would recommend XXX's for every situation, no matter the power input. Adire would recommend tummults for everything where budget isn't a concern. Clearly these drivers, even being their top of the line and arguably their most accurate drivers in terms of distortion, are not the best driver to use in every situation, even if they would reproduce less distortion in some test criteria.
You only want to come back to one thing, distortion output. Tell me, is distortion output the only thing YOU consider when deciding on a speaker? Go ahead, try to tell us you do, because we both know you dont.
I like this part:
"Now would I say it would necessarily provide the most output for that power level? Not necessarily, but I never made that claim."
No, you haven't made that claim. You are being very careful to only address the distortion levels, as you know this is your only winning arguement here. I on the other hand am talking about the full range of whats expected out of a subwoofer, not just distortion output levels. Does the sub play the lows with authority. Does it play a relatively linear across its entire bandwidth? How is its transient response? Etc. Yet all you want to talk about is distortion, as you know that is a winning arguement. Unfortunately, its not the topic at hand here. Again, please show me where I have stated distortion will not go up.
If the picture were so black and white as you state it, sub A has less distortion output than sub B, why do we not simply measure the distortion output of all the subs, and declare one sub the grand champion and best sub ever? Because we all know that there is more to a sub and how it sounds/performs than raw distortion numbers.
"Remember, the claim being refuted was not "You might be happier with X driver because your power levels are are closer to the maximum of that driver than driver Y." The claim was "Use driver X because it will sound better than driver Y, because driver X is closer to xmax at the power level specified."
You cannot refute the latter claim, which is blatantly false, by attempting to prove the former claim. That is precisely what you are trying to do."
That's some pretty twisted logic. All Im trying to say is the sub with the least distortion output isn't necessarily the sub that will sound best to the listener in every circumstance, which is what you are trying to say. If a guy only has 400 watts to work with, I see no reason why the XXX will have a decided advantage in how the system 'sounds'. I totally agree the XXX will technically have less distortion output than the SE at any given excursion level, but again this is a more complicated situation than simply 'which sub has less distortion'. Keep in mind, many people actually prefer the sound of a non BL optimized driver because they are so use to hearing that distortion inherant in traditional designs. But wait, according to you the sub that technically is putting out less distortion always sounds 'better'. Getting it yet?
Increasing power will NEVER result in better SQ. Ever. With any driver. Period. It is undeniable, indisputable fact.
This is the crux of our disagreement, the statement you made above. Again you are only going by the strict definition of SQ in terms of distortion output. When someone reviews a sub, do they simply chart out its distortion levels then move on to the next sub? No, they -actually listen- to it, and critique its performance in various areas.
You should be more careful with your blanket statements, you are getting a bit too overconfident with your 'my arguement is irrefutable' attitude. Adding power will NEVER result in better SQ eh? Im sure anyone that listens to a system at 1 watt (or some low amount that does not allow the details of the music to be play with enough authority to be perceived), then turns the power up to be able to hear those highs better, to feel the low notes as they were intended (rather than some little bump bump bump that's barely even audible) would disagree with you.
The problem is your rigid definition of 'SQ', only wanting to attach the distortion output level to this term. Only in this arguement, Im sure you argue 'SQ' is a culmination of many things (to many people) in some other thread that wouldn't make it appear as though you are changing your story. Or, are you trying to convince us 'SQ' is nothing more than measuring distortion output levels? With all your talking here, you still have not addressed this point.
Now will you be fully utilizing the potential of the XXX? No, obviously not, but that wasn't what we were debating. I said from the get go that that was the ONLY reason you would ever recommend the lower level drivers, because your average user wants to use whatever driver they purchase to the fullest extent possible. Most would be annoyed if they purchased a driver with a 32mm xmax and it only moved 8mm with the power that they had available.
Not to mention, they'd be mad if they realized they could have bought an SE that probably would have gotten more excursion than 8mm with that low powered amp, and sounded 'better' (due to more output, more authority in the low end, etc) doing it. Yes you can (and Im sure will) say the XXX would be putting out less distortion, but again that's not the only issue at hand here (just the only one you want to address).
No no, I'm not disagreeing with you //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I'm actually trying to figure out why Audioholic is still arguing with you (physics vs. audioholic, who will win?). Just pointing out that I don't think they were recommending to only increase power by 150w, but rather to double to the power to each sub.
Why is this attitude from you not surprising to me at all? //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Show me where Im arguing -against- physics smart guy.
warbleed, Im truely interested in learning here. Im not saying my reasoning here is right, I may be wrong and a XXX would sound 'best' in any power level over any other RE sub, but frankly your reasoning of it just coming down to distortion levels jsut isn't cutting it for me. I dont see thigs being that black and white. I would like to continue this further (and maybe have some other people join in, other than peanut gallery comments like the one from squeak), but if you wish to continue to talk to me lusing terms like 'idiotic' or 'irrational', I'll simply stop posting. I certainly agree you know more about speaker designs than I do, but this does not give you the right to talk down to me in such a manner. Being a moderator at CAF, Im surprised to see you still have this attitude still. Winning? Im not here to win (unlike you?), Im here to learn. Get off your high horse, you aren't all that and the bag of chips you make yourself out to be. Have a nice day.
