this basically saying that quality is not necessarily lost when burning the data, but when reading it... so if you're using an old or crappy/cheap cd reader to copy the original from, there will be some quality loss on the duplicateIt should be pointed out that, while digitally extracted audio is an exact copy of the data on the CD, it's an exact copy as your CD player perceives it. Different drives or different runs with the same drive can extract slightly different data from the same disc. The differences are usually inaudible, however. Some newer drives will report the number of uncorrectable errors encountered, so you can get a sense for how accurate the extraction really is.
The quality of the audio on the duplicate CD-R, given a high-quality extraction, depends mostly on how well your CD player gets along with the brand of media you're using. See the next section for some comments about avoiding clicks and pops.
Some older drives have trouble starting at the exact start of audio tracks. The extraction starts a few blocks forward of where it should, and ends a few blocks later, so the track may not sound quite right and the extraction program will report errors at the end of the last track. See section (4-19).
again with older/low quality hardwareOne user was told by Yamaha tech support that crackling (similar to a dirty vinyl LP) was a symptom of laser misalignment. If you've been writing audio CDs for quite a while, but lately you've been getting "crackly" results from tried-and-true media, this might be the culprit.
audio tracks dont have ECC data and may have errors when duplicatedmany CDROM readers do not perform error correction of the data when doing raw sectors reads. As a result, you end up with errors on the copy that may or may not be correctable. When you make a second-generation copy of the same disc, you will make a disc that has all of the errors of the first copy, plus all of the new errors from the second reading of the disc. The cumulative errors from multiple copies will result in a disc that is no longer readable.
Audio tracks don't have the second layer of ECC, and will be susceptible to the same generation loss as data discs duplicated in "raw" mode. Some drives may turn off some error-correcting features, such as dropped-sample interpolation, during digital audio extraction, or may only use them when extracting at 1x.
We run a Unix based system at work and guess what? It crashes all the time. Temp aint the problem either. Go MilSpec!A computer shouldn't ever crash, unless it has a thermal problem.
Computers crash because programmers do not adhere to a standard in coding.
If my program (1 minus 1 = x. Write x to register A) writes to a register, and doesn't clean up after itself, that register may cause your program (Divide 1 by x from register A) to crash upon reading it - of course, avoidable with proper precautions.
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
sound card on ur computer also affect the sound of all ur mp3's, with a better sound card, u can notice difference when burning cd's...
There is a difference, quite large to me. I have the Jeezy CD burned from 196 kbps MP3s and the original copy is MUCH clearer and not to mention LOUDER than the burned copy.
