Reading Coils With a DMM
sundownz
Pro Seller
Supporting Vendor
I use a ~$300 DMM to measure our coils here at the shop... why ?
Well I'll show you...
* Our Dual-1 coil on a cheap meter.
* On our meter - factory spec is 0.84 ohms +/- 12%. This thing is dead on.
* Our Dual-2 on a cheap meter.
* On our meter - factory spec 1.85 +/- 12%. Again... 12% variance allows up to 2.07 and the meter only reads to the tenths place so it is dead on.
So. Keep that in mind when reading your coils on a cheaper meter.
Much of it is lead resistance - correct.
The cheap meters I've used also jump around alot measuring a coil - my meter is quite solid once it gets its reading. It will jump at most 0.1 back and forth. The little meter was jumping by 0.3 or so.
as long as it's close enough, I don't care. close enough to know that the company labeled or shipped the correct VC config. $300, no thanks, i'd rather buy more speakers //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i use a $900 Fluke (of course i didn't pay hardly anything for it) its pretty much balls on. It also has a temperature sensor and can force a 4-20 milliamp signal (i do a lot of intrumentation loop tuning at work where you need to test unpowered instruments)
i use a pair of flukes i bought as a set($650) one is a true rms meter and the other is a clamp meter/amp probe that dose ac and dc amps. very, very accurite.
i bought a box of 40+ meters at an auction for $500. Most of them were fluke's and about half of them were still brand new...i found that $900 meter in the box also, so i kept that one and sold most of the others
what ya got left? iam looking for another dc amp probe...
We use flukes for any of our EE labs... I brought in my cheapo one I use for projects one time to compare them and it was pretty significant. I don't know if I'd spend the money on a fluke for projects as long as you keep in mind the properties of a cheapo one. Guess it depends on your use.
Calibration of anything I'd say either buy or maybe even see if you can rent a fluke. I know I bum one off the EE lab to configure my stuff when need be.
As far as just general measure and checks go normally my cheapo one is all I need.
Good thought to bring up on a forum like this =)
Error ratings are higher in all digital meters when low measuring values are concerned. You can increase the accuracy level of a meter simply by using a 100 Ohm precision resistor in series with your voice coil. A 50 cent fix for a more accurate reading //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Best,
Mark
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
sundownz
