Will 2 RE 8's ported wang pretty hard off of 100 watts rms a piece. I want to buy them buy the end of the day, so please respond.
Yes, just like 2 12s would be better then 2 10s. Just depends on what you want, how much space and money you have to work with. Of course a lot depends on the install itself as to how it will sound and how hard it will hit.would 2 re 10's be better.
Port them in that box and you will be amazed at the out put you will gain.I have two RE8s in a .7 sealed box, with 150 watts to each. More than enough power to make them bottom out if the volume is turned up. They sound great for what they are, and the size, but they aren't going to compare to alot of larger subs. It easily out does my friends 12" rockford, but I use to have a 12" crystal CMP with 800 watts to it, and that obviously was a better setup.
They aren't bad, but if you have space, I would run a nice 12" or 10".
That's a big yes. I didn't have any more room with my setup. Wish I did, but it turned out fine.I thinking 1 cubes ported
