best thing to do, is build you (or borrow) a sealed box. toss one of the subs youre gonna use in there, and measure the frequency response in your car, and outside (in an abandoned parking lot (if you can find one) or if there's an anechoic booth you have access to. there should be a peak right between 50 and 55 hz...that shows up on both of the rta printouts (when you lay one on top of the other) and thats your resonant frequency. then use winisd. figure out what the biggest possible box you can build is, and tune it so that the peak is right at the resonant frequency (dont tune it TO the resonant frequency, cuz it will peak wrong, and youll lose output)...
bottom line...bigger box, perfect port, bigger peak.
bigger peak...more trophies //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
eric
