The Resonant Engineering 12SX the foam part of the cone has a couple of little rips in it. see picture. 165+shipping. retail over 400 i think now.
http://www.reaudio.com/
Specs:
RE/DCR 1.9ohm DVC, BI21, 1000RMS 2000 Peak
FS 30.6
Qms 4.4
Qes .32
Qts .30
Mms 183
Vas 47.6
SPL 88.1
Sd 480
Cut diameter 11.125
Mount Depth 6.875
Displacement .16cuft
The AMP: 165+actual shipping+materials
Phoenix Gold Octane R15.0.1
Comes with a Bass Control Knob. i'll even send the thing i placed it on which was the bottom the the seat so u don't have to drill holes. if you have a black interior g Coupe
Specs:
MonoBlock Class D Amplifier
Suggested retail price: $599.99 each
Product Description:
High efficiency class "D" monoblock amplifier
Black with aluminum insert and blue illuminated carbon fiber badge and blue LED backlit PG logo
Adjustable input sensitivity control
18dB Low pass variable crossover: 30Hz-300Hz
18dB Subsonic filter: 20Hz-55Hz
Twin "T" Bass EQ Circuitry -- Adjustable 0 ?15 dB @ 45Hz bass boost
Muting circuitry for soft turn-on and turn-off
Advanced overload and thermal protection circuitry
Silver high-current power and speakers terminals
Silver RCA level inputs
Auxiliary RCA output
Optional LPL Low Pass Level remote control (Not Included)
Optional RMD port (Remote Monitoring Display) (Not Included)
Optional blue neon illuminated side rails (pictured, but not included)
Dimensions: 16.5" (L) x 10.875" (W) x 2.25" (H)
Amplifier Specifications:
Number of Channels: 1 - Mono
RMS Power (4 ohms): 500 watts
RMS Power (2 ohms): 1000 watts
RMS Power (1 ohm): Not stable
Bridged RMS Power: Not Bridgeable
Peak Power Output: 1500 watts
Min. Impedance Unbridged: 2 ohms
Min. Impedance Bridged: Not Bridgeable
THD @ Rated RMS Power: N/A
Speaker Level Inputs: No
Amp Preamp Outputs: Yes (1 Pair)
Built-in Crossover: LP (30 - 300Hz), Subsonic (20 - 55Hz)
High-Pass Crossover: N/A
Low-Pass Crossover: N/A
Subsonic Filter: N/A
Signal-to-Noise Ratio: 90 dB
Channel Separation: N/A
Bass Boost: 0 - 15 dB
Bass/Gain Remote: N/A
Fan Cooled: N/A
Fuse Rating: 40A x 2
This Amp NEVER GAVE ME A PROBLEM
Feedback
EBAY: kevinrt8700m5, Azndrunkyoon(someone hyjacked SN and ebay shut this one down) i have no Negatives and i sell alot too.
s2ki azndrunkyoon
e46fanatics.com mhschiefs806
g35driver kevinrt8700m5
g35frenzy kevinrt8700m5
Specs:
FS 30.6
Qms 4.4
Qes .32
Qts .30
Mms 183
Vas 47.6
SPL 88.1
Sd 480
Cut diameter 11.125
Mount Depth 6.875
Specs:
Fan Cooled: N/A
Feedback
s2ki azndrunkyoon
