Sold Re Se D4 10" ---- Mint ----
Can't send a pm. I'm on a mobile phone. What's the recomended potted box size?
Here are the specs on the sub, I also Pm them to you, this is still for sale and I have had alot of tire kickers however no cash as of yet. Lets get this sold, ya know ya got some xmas cash. Do it!
RE Audio is known to make some of the best hard-hitting subs and amps. These are competition grade subs, which go super-loud. These are made with the best surrounds so they can withstand a lot of bass for long periods of time. With 600 true RMS watts, this sub is one of the most powerful 10" subs on the market. These are rated strictly. They do not have inflated peak ratings like some other lower brands do.
This is made to be a high excursion sub. This means it can hit a big range of frequency, and it can also pound a lot louder without over-heating.
Features:
* Impedance : Dual 4 ohm voice coils
* 600 watts true RMS Power! (No bootleg power ratings like cheaper brands, this is a huge 20 pound sub!)
* One-Way, Linear Excursion -Xmax: 18 mm
* Efficiency - SPL 1W/1m: 83.2 dB SPL
* Effective Piston Area -Sd: 310 cm^2
* DC Resistance -Re: 2.8 ohm
* Mounting Depth - 6"
* Mounting Hole Diameter - 9.25"
* Overall Diameter - 11"
* Bolt Hole Circle - 10.125"
* Motor Width - 6.25"
* Motor Depth - 3.25"
* Basket Depth - 2.75"
* Displacement - .14 cu. ft.
* Weight - 20 lbs.
* Dual Composite 2-piece Cone
* Rubatek Foam Surround
* Cast Aluminum Basket
* Tork-Tite Terminal
* 3" 4-layer Aluminum Voice Coil
* FEA Optimized Motor Structure
* Triple Stack Maganets
* Progressive Spiders
* Qes: .46
* Qms: 4.4
* Qts: .42
* Free Air Resonance -Fs: 26.6 Hz
* Vas: 31 liters
* Wrap around Rubber Gasket
ALLOUTGEAR
A little Off
ALLOUTGEAR
Cali
ALLOUTGEAR
