Item(s) for Sale: RE Audio XTX-3000.1
Item(s) Description/Condition: 10/10 Mechanical had about 6 months ran on good electrical, have had zero problems from this. Lowest load it has seen is 2 ohms. 8/10 Cosmetic small scratch here and there, but mainly 8/10 because one of the plastic feet is cracked, can be super glued. Didn't do it myself because i only had 2 of the feet on while mounted.
Product Features:
XTX Series Monoblock Full Digital Car Amplifier
RMS Power Rating (14.4V):
4 ohms: 600 watts x 1 chan.
2 ohms: 1000 watts x 1 chan.
1 ohm: 1400 watts x 1 chan.
Dynamic power output: 3000 watts
Pulse Width Modulated MOSFET power supply
LED power (green) and protect (red) indicators
Wired remote included
Selectable bass boost with frequency control (0-12 dB at 30-80 Hz)
Single channel operation
2-Way System Protection circuitry (thermal and short circuit)
Heavy duty brushed aluminum alloy convection cooled heatsink for efficient heat dissipation
Nickel-plated RCA level inputs
Nickel-plated 8-18AWG screw terminals
Input sensitivity:
Low level: 100mV-6V
Variable low-pass filter (40-180 Hz, 24 dB/octave, Butterworth)
Subsonic filter (17-50 Hz, 24 dB/octave)
Signal to noise ration: 90dB
Phase Shift Control: 0 - 180°
Frequency response: 17-180 Hz
Dimensions: 9-1/4"L x 14"W x 1-15/16"H
4-gauge power and ground wiring is required for installation.
Price: 150 + shipping
On you.. Will be willing to drive 75-100 miles if this is bought with the SSA XCON i have for sale, otherwise limit this one by itself to a 50 mile radius of 35010.
Product Features:
Input sensitivity:
Low level: 100mV-6V
