RE Audio DTS1500.1 and DTS750.2
  • 4
AnthonyO
Budget Banger Connoisseur
Item(s) for Sale:RE Audio DTS1500.1 and RE Audio DTS750.2
Item(s) Description/Condition:Selling both of my amps. They are used. On a scale of 1-10 10 being best: Appearance 9 only because they have been mounted Function: 10
Price: $200 shipped in the US for both
RE Audio DTS1500.1 Specs
DTS Series Monoblock Class D Car Amplifier
RMS Power Rating (14.4V)):
4 ohms: 410 watts x 1 chan.
2 ohms: 700 watts x 1 chan.
1 ohm: 1000 watts x 1 chan.
Dynamic power output: 2000 watts x 1 chan.
Pulse Width Modulated MOSFET power supply
Wired remote bass level control included
LED power (green) and protect (red) indicators
Variable Bass Boost (0 to +12 dB bass boost at 45 Hz)
Bridgeable with multi link technology (MLT)
Mono channel operation
Preamp RCA outputs to daisy chain multiple amps
2-Way System Protection circuitry (thermal and short circuit)
Dual speaker terminals simplify the hookup of multiple speakers
Heavy duty brushed aluminum alloy convection fan cooled heatsink for efficient heat dissipation
Nickel-plated RCA level inputs
Nickel-plated 12AWG screw terminals
Input Impedance: 20 K-Ohm
Input sensitivity:
Low level: 100mV-6V
Variable low-pass filter (40-180 Hz, 24 dB/octave)
Subsonic filter (17-50 Hz, 24 dB/octave)
Bass frequency (30-80 Hz)
Effective damping factor: 150 @ 4 ohms
Frequency response: 17-180 Hz
Dimensions: 14-9/16"L x 8-11/16"W x 2"H
4-gauge power and ground wiring is required for installation
RE Audio DTS750.2 Specs
DTS Series 2-Channel Class A/B Car Amplifier
4 ohms: 75 watts x 2 chan.
2 ohms: 130 watts x 2 chan.
Bridged, 4 ohms: 260 watts x 1 chan.
Dynamic power output: 600 watts
Selectable bass boost (0, 6, 12 dB at 45 Hz)
2/1 channel operation
Heavy duty brushed aluminum alloy convection cooled heatsink for efficient heat dissipation
Input sensitivity:
Low level: 200mV-2V
Variable high-pass filter (50-500 Hz, 24 dB/octave)
Variable low-pass filter (50-500 Hz, 24 dB/octave)
Effective damping factor: 300 @ 4 ohms
Frequency response: 20-36,000 Hz
Dimensions: 11"L x 8-11/16"W x 2"H
8-gauge power and ground wiring is required for installation.
I will be using FedEx or UPS for shipping
RE Audio DTS1500.1
RE Audio DTS750.2
A Link would be very helpful. Id be interested in taking a look at some gear
174
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
284
AnthonyO
AnthonyO
Minot, North Dakota, United States
AnthonyO
