re 8's or soundsplinter 8's?
thx 4 the info.. i like the fact the ss has 18mm xmax which is sick.. looks like they handle they most too .. but weigh in @ 18 lbs ... and i tried to order then on the site .. says out of stock.. also the aa's r 45 bux each, re's 98, and ss 145. dunno bout the dd's
Do you have a link where the AA are $45 each?
ok so since the rli's arent available which ****in sux... i guess my options r the assassins or the re.. again do u guys think id b better off with 2 10"s? or would the 6 8"s b alot better?
6 of that amp aint gonna push them that bad..i had a plan to run 4 off a sundown or md3d
i think this amp is perfect for what im doin.. the hard part is findin a sub that will perform well in small sealed box... like i mentioned b4 i like the xmax on the SS and the fact its beefy.. the re 8 looks weak compared to the SS and assassin..
ok so heres the rundown...
1.SoundSplinter rli-8 power 200-500rms xmax 18.3mm weight 18lbs price 149each(2 or more)
2. Ascendant Audio assassin 8 power 150-350rms xmax 15.5mm weight 13lbs price 45each
3.Re audio power 175rms(per coil???) xmax 12mm? weight 6lbs price 55-98each
all 3 have a mounting depth of about 4"-5.65"
anything else i need to look @ performance wise? any other 8" subs @ the same price range compare to these stats?or am i better off with 2 10"s-2 12"s?
hope this wont be too long..
but give me ur thoughts and opinions on my setup what do u like/dislike.. change etc?
HU:
JVC kw-avx800 (had it a week and i love it)
http://mobile.jvc.com/product.jsp?modelId=MODL027892&pathId=133&page=1
EQ:
AudioControl EQS(6 chan eq+line driver)
http://www.mobileaudiocontrol.com/product.asp?Product_Id=14160&d_Id=5248&l1=5248&l2=
Mids/Highs:
Image Dynamics horn set w/6.5" mid
http://www.imagedynamicsstore.com/idstore/image-dynamics-cs16mh-hlcd-component-system-p-127.html
Subs:(undecided)
6/ 8" subs dunno what brand yet
Amps:
sub amp Rockford Fosgate T1001Bd (birthsheet says 1517@1ohm
http://www.rockfordfosgate.com/products/product_details.asp?cat_id=2&series_id=7&family_id=22&item_id=95251&locale=en_US&p_status=
Mids/highs amp Phoenix Gold Tantrum 500.2
http://sonicelectronix.com/item_5192_Phoenix+Gold+Marine+Tantrum+500.2+MT500.2.html
Battery/wires:
prolly gonna go with an odyssey batt.
300 amp alt.
Big 3 upgrade with 1/0 wire
1/0 wire to dist block for amps
rcas?? r monsters ok?
give me ideas and links to good wire to use and rcas..
thx fellas appreciate it
n00b
n00b
dallas,tx
n00b
