RE *** 12 d4
i actually took your suggestion and started scouring forums for Sundown and Skar, and saw Skar actually selling dual VVX 12 with a free sub box for $389, might not be a bad deal, dual Americna Bass XFL $350 could not find any b stock for sundown SA-12
The SKAR deal is GREAT but stay FAR AWAY from XFL's those things blow like no other.
yeah, way to adament for a noob.you still interested in the belle?
Looks like he finally opened up his ears and went with Skar VVX, so if he feeds them properly....good stuff.
I am definitely still interested in Big Belle, but I be $horty rite now. Found deals on 3 sets of comps I couldn't pass up //content.invisioncic.com/y282845/emoticons/blush.gif.99bc659ee2012b7d826165e26fb5eebe.gif
ahhh god.. Skar.. ill bite my tongue but am by no means a fan. and no problem. ive been in situations like that before.
if i still got it, hit me up.
when i was searching through the forum this statement from sundownz himself talking about SA and VVX
"What you will likely find in a drop-in test is the Skar being as loud or possibly louder really low (in the 20s and lows 30s) and the SA being louder at 40+ hz
Has a lower Fs and a bit more linear excursion than the SA but less motor force and more mass.
Typically in a comparison of two woofers with these differences that is what you will see."
Ok?
Here's another one from Sundownz
"I thought I explained it pretty thoroughly somewhere -- perhaps search button my name + SKAR Audio
Skar sub was designed with a bit higher linear x-max (via a longer coil which is also heavier) and a bit less motor force factor -- all of which are beneficial to low-end extension.
The SA was designed with a 10% shorter coil (lighter, few mm less linear x-max) and more motor power -- which are beneficial for SPL.
Either subs sounds quite good, IMO.
Neither is an "SPL Sub" or an "SQ Sub" -- they are both versatile and can go either way; simply leaned each one a bit farther in each direction."
I just bought the one who had a b stock, if both had b stock, I most probably still go with Skar just because he is in Florida (helping local economy), I could not tell where sundown is from.
To my ear from what Sundownz said, I probably wont be able to tell the difference from SA and VVX
Not really helping a local business when you didnt buy from a local dealer and the subs are produced in China lol
Not sure why everybody is so negative on when its produced in China. When most of the stuff here in US is not made in the US.
I guess I'm opening a can of worms here
Your helping to build a Chinesse army thats going to kill us all.... So am I! I like war, its job security
Job security? why get mad at the Chinese they just accept the job that was given to them, in actuality you should be mad at the Americans who send the job to China, and do you really think these companies would've survived without outsourcing with the bad economy?
naughtyca
naughtyca
Tampa FL
SPLaudio
