RE 12.1 = audiopipeGD 3001
If you look around that site, you'll also notice that the american bass 150.1 and the hifonics bx2200d have the same board. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The lanzar opti4000d and the soundstream xxx6500 also have the same board. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
But thats not to say they all use the exact same components though. Using the same board is like using the 12-spoke basket. Sure, alot of companies use them, it doesn't mean that all the subs will perform the same. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
The RE 12.1 was bench tested to to 1489 RMS at 14.4v. The RE 12.1 makes that other amp look like your dogs hairy balls coughed up outta your momma's mouth.
All else being equal and assuming that Audiopipe actually outputs 1200w @ 1 Ohm there's not going to be an audible difference on the same driver(s) in the same enclosure going from 1200 to 1400+ watts, //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
If you look around that site, you'll also notice that the American bass 150.1 and the phonics boxed have the same board. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The Lazar opti4000d and the sound stream xxxii also have the same board. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
But thats not to say they all use the exact same components though. Using the same board is like using the 12-spoke basket. Sure, alto of companies use them, it doesn't mean that all the subs will perform the same. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I see what you mean, but i dont think that when boards look IDENTICAL it can be compared to companies using the same 12 spoke basket...
I think it would be fun to test....
so, just because one is "RE", means the other is inferior? is it not worth testing?
just like your typeR performed better than your "RE" sub, did you make this up?//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Hehe, you know what i mean. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Its not worth arguing about until we see some real world bench tests of both amps. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Dont forget ext-2000d with the vfl
BoominBeast
Banned
BoominBeast
MI
helotaxi
