rd sonance vs si bm's
By specs...
The BM has more x-max, a lower Fs, and a slightly lower Qts... by specs it seems that the BM will have more low-end extension and output.
The Sonace has a significantly higher BL so it would likely meter higher for SPL competition, though.
BM is on sale right now too //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I have used the BM and it's a great woofer for SQL, especially ported, IMHO. Have not used the Sonace but the above is my conclusion based on the published specifications.
If you're going ported, the BM's can get pretty nasty. The 12" BM, in particular, leans towards ported enclosures more than the 10" models do.
There was someone on this board that sat in Hoss's truck (eight BM 12's in ~20 cubes ported) that aske me if the subs were Mag's. I told him no, they are BM's. He listened a little more and said "those are Mag's." I swore to him they were BM's (because they were), but Hoss's truck impacted so hard it was easy to mistake the BM's for Mag's.
and had a slight surface area advantage id imagne //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
No, the BM's are the same as the Mag's surface-area-wise. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
We did a local install with two BM 12's ported and it is louder than my two Mag 12's sealed that have double the power.
I did a 141 with the Mag's sealed in an Integra off a Colossus II, and the BM's were quite a bit louder in a RSX with a SAZ-1500D. My guestimate would be a 143'ish from the BM's if he would have gotten metered before he sold the car. Now the subs are in a 4-runner waiting to be hooked up.
there was never a question of mag's getting loud //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
pbplayer
pbplayer
carroll,iowa
denim
NorthFramingham
    Jun 30, 2026
