rd d5 for sale
mazdakid
RD D5 amp in d3250.1 case
Amp is in pretty good condition, has a few scratches and a mark that i took a picture of.
The amp was a prototype and there were 12 of these amps made in this casing. I can get better pics when i take it out of my car.
$530 shipped
Uploaded with ImageShack.us
$520 shipped
One of those pics makes it look like the fins on the side of the amp are bent, but i guess it was just my camera.
Ill clean up all the saw dust and take more pics if anyone wants.
Talon is my username on caco, i didnt steal anyones pic.
whats the specs on this amp?
This took all but 5 seconds to google. Google is your friend.......
Digital class-D linkable mono block amplifier
MOSFET PWM power supply
Daisy-chain through output RCA
Heavy duty cooper layer double sided epoxy PCB
Stable into 1 ohm and 2 ohm parallel amplifier connection availability
24 dB low pass (LPF) crossover variable
18 dB bass boost equalization control variable
180 degree variable adjustable phase shift
24 dB subsonic filter variable
Selectable Switch for MASTER and SLAVE Operation
Speaker short, over current, thermal, and DC protection circuit
RCA line input and line output
2 x 0 guage (AWG) battery input connectors
Efficiency: 86% at 4 ohm, 100 Hz
Tested voltage & THD : 14.4V and less than 1% THD at 4 ohm RMS watt
Operating voltage: DC 10V ~ 18V power input
Damping factor: better 350 into 1 ohm
Wired remote controller
Specifications
RMS power, 2 ohm linkable/dual mono
RMS power, .5 ohms mono 3000
RMS power, 1 ohm mono 2000
RMS power, 2 ohm mono 1000
RMS power, 4 ohms mono 500
Signal to Noise Ratio >100dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 300 amps
Input Sensitivity 200mV to 6V (+/- 5%)
No? Thats straight from their website.
D5
Then what are the specs? It would help with your sale if you posted specs of the amps so people know what they are buying, especially if the specs are different than what they say their D5 specs are....................
Im sure I read it right. RD Audio D5 amp in a D3250.1 case....
mazdakid
mazdakid
illnoise
mazdakid
