Sold RD Audio D9 *Mint*
spltuscon
Kick-*** box builder
833
5
NH
Selling my very mint condition RD Audio D9. I bought it brand new last year and it has been flawless. Very powerful and really comes alive below 1 ohm. I have had this amp mounted on 1/4" thick neoprene foam with rubber washers above and below the mounting tabs for very good vibration resistance from day 1 of owning it. It was also mounted below my cargo floor on a 3/4" thick birch amp rack that was bolted to the truck about 12 inches from a group 65 battery with dual 1/0 power and ground leads so it was never starved for current or voltage. Basically I'm saying that I have treated it like my baby and whoever buys this will get a very nice amp.
I also have the original box, manual, and never used bass knob/cable.
Features
* Digital class-D linkable mono block amplifier
* MOSFET PWM power supply
* Daisy-chain through output RCA
* Heavy duty cooper layer double sided epoxy PCB
* Stable into 1 ohm and 2 ohm parallel amplifier connection availability
* 24 dB low pass (LPF) crossover variable
* 18 dB bass boost equalization control variable
* 180 degree variable adjustable phase shift
* 24 dB subsonic filter variable
* Selectable Switch for MASTER and SLAVE Operation
* Speaker short, over current, thermal, and DC protection circuit
* RCA line input and line output
* 2 x 0 guage (AWG) battery input connectors
* Efficiency: 86% at 4 ohm, 100 Hz
* Tested voltage & THD : 14.4V and less than 1% THD at 4 ohm RMS watt
* Operating voltage: DC 10V ~ 18V power input
* Damping factor: better 350 into 1 ohm
* Wired remote controller
Specifications
RMS power, 2 ohm linkable/dual mono
RMS power, .75 ohms mono 5400
RMS power, 1 ohm mono 3600
RMS power, 2 ohm mono 1800
RMS power, 4 ohms mono 900
Signal to Noise Ratio >100dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 500 amps
Input Sensitivity 200mV to 6V (+/- 5%)
$800 shipped and insured (includes paypal fees too)or $750 picked up with cash
Hey man, i lost your number. shoot me a text or a call or something. hopefully we can work something out for that beaut505-629-3993
I have a buyer pending payment, but if he doesn't come through today then I'll text you later and we could probably work something out.
spltuscon
spltuscon
NH
CL1CKCLACK
