RCAs
Lil_KB
Ok, the amp wiring kit I bought doesn't come with RCAs, so I'm gonna get some knuconceptzs ones. This is my first time wiring up a system. Which ones do I need? Will 4 meters be enough or should I go with 6 meters? Do I get the 2 channel or 4 channel ones?
As far as length goes, you need to measure how long you would need them to be to fit your application. Weather you get 2 ch or 4 ch depends on what signals you need to send. By looking at ur sig and assuming they will be used for the tacoma, its looks like 4 meter 2 channel RCAs will be fine because its a truck and its looks like you only need for the sub setup. Hope this helps.
A 2 channel RCA has two RCA connectors - one left, one right, a 4 channel has four RCA connectors, one Front left, one Front right, one Rear left, one Rear Right. It is two 2 channel RCA's in one cable. Of course they could also be used for a sub amp if you use a 4 channel amp bridged.
Lil_KB
Lil_KB
Louisiana
knukonceptz
BP1Fanatic
BP1Fanatic
