RCA's
personally I would never go with cheep RCAs but they will work... all your sound quality will be in your RCAs from the HU to the amp
I challenge you to identify the difference between $10 RCAs and $200 RCAs by ear. Even with the cheapest of the cheap RCAs you would not get a significant loss of signal. You would be hard pressed to be able to measure the difference with the most expensive test equipment. You're looking at distortion in the 0.0001% range. Excellent amps have distortion figures several orders of magnitude higher, and it's still inaudible.
With a small home system (low voltage line level signals) RCAs are of marginal concern, despite what the cable manufaturers would have you believe.
Do a true ABX test of RCAs and then say that //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Buy RCAs based on quality of construction and your budget, not SQ.
4runnercrazy
Mattchu
4runnercrazy
Danville,CA
JimJ
vegang
vegang
