rca from hu to amp
i have a jensen headunit with only 1 female connect for rca to hook up my amp for the subwoofer. On the amp their is the typical L & R connections for my rca. Do i need a Y adapter to hook up to the head unit?
No, subwoofers are mono, not stereo, so you only need to connect one side of the signal. You can use a Y-splitter if you want to for asthetics and visual appeal, but there won't be a difference in performance.
I have a mono out from my HU as well.
My amp has the option for a mono input or for multi-channel input. I found that I got more output from the amp by using the multi channel input with y-cables and didn't have to use as much gain to get rated power from the amp.
You might want to experiment and see what works best in your case.
FunBoyThomper
FunBoyThomper
houston tx
FunBoyThomper
