rca cables gone bad ?
  • 4
slain93gsr
Prying Open My Third Eye
286
Wisconsin
how do i know if my rca cables have gone bad . dont have a chance to get to a multimeter till the weekend.
having a intermintant noise from my components with the car on and off... dont have extra cables to exchange and test.
thanks
Howie
thanks
Howie
Try hooking up a cd walkman or something up to the rca's first to see if you still get the sound, if you do, you've eliminated the HU. Then, check all your grounds to make sure they are good, if that doesnt fix it...well, you're going to have to try another set of rca's and see if that fixes it, lol.
i'm thinking it might be the 9835 itself.//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif gonna have to send it out .
basically jinx myself from the 9835vs 860 debate lol
Try the cd walkman thing though, It would be a ***** to send it out if all it is is your rca's...
See if using a different pair of rcas such as the rear or fronts still has the noise. Its worth a shot.
Yes, you could do that, but doing the cd walkman thing can eliminate the HU definitely. Changing RCA's you could still have the problem and it still be something else...
well i threw in my friends pioneer model to test and it worked like a champ..realized how much difference in sq there was between a good deck and a mediocre deck..
how do you hook up a walk man to the rca's please forgive me as i'm a bit intoxicated from my night of drinking.
i **** at life ..lots of bad things happening in my life at the moment..//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Well if your friends pioneer worked then it is ur HU.
well lets see how long it takes alpine to get it back to me.. i'm trying to find time to take it to a dealer to get it sent out.
Howie
No make or model number on it? Do you have an exact picture of the rear and all its glory?
516
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
483
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
461
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
672
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
761
slain93gsr
slain93gsr
Wisconsin
slain93gsr
chipss36
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
