Rate my 500$ Setup!!! LOW BUDGET/GOOD QUALITY!
slanteyez
4
SD
Hey guys I've done research and I FELL IN LOVE WITH ASSASSINS!! was wondering if you guys can rate this setup or anyways to make it even better! Like different amplifier maybe???
200$ 2 12' Ascendant Assassins http://www.ascendantaudio.com/assassin12specs.html
50$ 12 Dual Box 1.2cu FT http://cgi.ebay.com/Dual-12-inch-Sealed-SUB-BOX-TWO-Subs-Woofer-Subwoofer_W0QQitemZ190058908756QQihZ009QQcategoryZ50565QQrdZ1QQcmdZViewItem
208$ Infinity Reference 611a http://cgi.ebay.com/INFINITY-REFERENCE-611A-761-WATTS-MONO-SUB-AMP-NEW-06_W0QQitemZ290058892635QQihZ019QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
30$ 4Gauge AMP wiring kit http://www.knukonceptz.com/productDetail.cfm?prodID=eKo-K4
GRAND TOTAL = ABOUT 500$
Doesn't look too bad for the sub setup.
That's no budget system though. I put together a budget setup with an AE av12, Directed 1500d, Polk 300.2, Kenwood 6023 headunit, Cadence componets, wiring and an enclosure for $750.
I would seriously consider building your own ported box and maybe a different amplifier that has a lower price with equal or greater performance than the infinity.
similar to what i did for my budget subwoofer setup.
two AA assassin's
q-logic sealed box
profile ap1000m amp
some cheap 4awg kit
if at all possible i'd build your own (ported) box, the output gain will be significant.
also you could probably find similar amounts of power for less money.
psssh no active frontstage //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
there is nothing wrong with the assassins pretty darn nice sub for the price
So much for positive responses. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I do agree that you'd be better off building your own box. A sheet of MDF is only $20 + $10 for glue and screws, but you'll end up with a MUCH better box that's spec'd perfectly for the subs.
Could also shop around to find equal/more power for that price or less. Assassins are very good "budget" subs. VERY happy with the 2 8's I bought a few months ago. Good luck....
slanteyez
slanteyez
SD
Immacomputer
