RARE SQ HU Copper Chassis Rockford Fosgate RFX9220G
CerwinVega_Fan
Coolest Member
4,474
Dallas,TX
RFX9220G
Works 100%. Has a small chip on the vol. knob.
These are very rare and hard to come by. I believe these were made by Denon.
Really nice SQ unit here.
Rockford Fosgate RFX9220G (Discontinued 2005/2006 Model) - Abtec | Online Car Audio
$650 plus shipping
Will entertain trades for tc/la storm 3hp neo motors, 4hp subs, mmats 4000.1 or 3500.1.
I guess no one wants this rare piece of car audio.
//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
i have the rockford 8140 from 1998 with remote box and disc changer and i wouldn't sell it even if it is a dead head the 8.5v pre outs is great to have
this looks nice and GLWS man if i had the funds you would have it sold
Specs
General Model 9220
Operating Voltage +10.8V – +16.0V DC
Standby Current 5mA Max
Operating Temperature Receiver: -30˚C to +70˚C
CD Player: -10˚C to +65˚C
Dynamic Power Rating 40 watts x 4
per channel into a 4Ω load
RMS continuous power per channel, all 13 watts x 4 (4Ω load)
channels driven from 20-20,000Hz with less 17 watts x 4 (2Ω load)
than 0.5% Total Harmonic Distortion (THD)
Speaker Impedance 2Ω – 8Ω
Preamp Output Voltage 5V RMS @ 0.5% THD
Sum Preamp Output Voltage 5V RMS @ 0.5% THD
Preamp Output Impedance
Equalization Bass: ±10dB @ 60Hz
Treble: ±8dB @ 15kHz
IR Receiver Eye Range ±45˚ off axis
Overall Dimensions (with trim-ring) Height: 2-9/32" (58mm)
Width: 7-13/32" (188mm)
Depth: 7-1/4" (183.7mm)
Nosepiece Dimensions (without trim-ring) Height: 1-27/32" (46.5mm)
Width: 6-3/4" (171.5mm)
Depth: 13/16" (20.2mm)
Weight (Mass) 3.13lbs (1.42kg)
FM Tuner
Tuning Range
Americas 87.5 ~ 107.9MHz (200kHz spacing)
Eur/Aus 87.5 ~ 108MHz (50kHz spacing)
Frequency Response 30Hz – 12kHz
Usable Sensitivity 10dB (S/N 30dB)
IF Rejection 90dB
Image Rejection 50dB
Signal-to-Noise Ratio 60dB
Distortion
Channel Separation ≥ 25dB @ 1kHz
Suppression 35dB
AM Tuner
Tuning Range
Americas 530 ~ 1710kHz (10kHz spacing)
Eur/Aus 522 ~ 1620kHz (9kHz spacing)
Sensitivity 20dBf max @ 10dB sensitivity
-6dB Bandwidth 5kHz min – 12kHz max
CD Player
Compatible Discs 5" or 3"
Frequency Response 20Hz – 20kHz (±3dB)
Signal-to-Noise Ratio >90dB (preamp output w/ 22kHz LP filter)
Distortion
Channel Separation 86dB (preamp output w/ 22kHz LP filter)
Dynamic Range 100dB
IR Remote
Operation Voltage +3V DC
Transmitting Range 20 ft (variable in sunlight)
Battery Replacement (2) AAA +1.5 volts
Dimensions 4-1/8"(H) x 1-13/16"(W) x 1-1/8"(D)
(104.8mm x 46.0mm x 28.6mm)
I like the MA Audio HK series ..ive ran and won with them at car audio comps
  • Locked
Nice crossover ..i have one it matches my Jensen BBE amps ....
  • Locked
You said, "one of." How many do you have? I'm guessing that you are keeping the best one(s).
5K
Zinc also conducts fairly well. I use zinc nuts and bolts on the terminal cups I build into my boxes.
761
CerwinVega_Fan
Coolest Member
CerwinVega_Fan
Dallas,TX
CerwinVega_Fan
    May 16, 2024
    May 16, 2024
