Ramos or ???? Help !
  • 4
Spddracer
Sounds Goooooood
1,337
Ohio
I am trying to get my brahma 12 to hit harder , (Impact More) its loud but doesnt have the impact I want , runnign it on a jbl 1200.1 , I have it sealed now and am going to try vented I guess , Already tried ported didnt work out well ! , The space i have I can fit this dim box in
20" high
19" wide
Bottom depth 20.5"
Top depth 14"
Can you figure out a slot port size for this ?? and what do you think I should have it tuned too ?? I listen to a little of everything ? but not much rap ! No need to vibrate the earth at 10hz
Well first off Venting and porting are the same animal. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Give me a short second and I ill see what i can acome up with with those dimensions . //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You have enough room for the same size enclosure I'm using or should I say my wife is using //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Mine is in a 2.5cuft ported tuned to 30hz the port is 4"x4" and 16" long. I'm only running about 800w to it. And it gets very, very loud and still sounds good. I don't listen to much rap either. It has a good all around sound. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by ramos You have enough room for the same size enclosure I'm using or should I say my wife is using //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Mine is in a 2.5cuft ported tuned to 30hz the port is 4"x4" and 16" long. I'm only running about 800w to it. And it gets very, very loud and still sounds good. I don't listen to much rap either. It has a good all around sound. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Theres no doubht it gets very loud in the ported enclouser I have , It hurts ! But it just seems to be lakcing in IMPACT , I dont know if you know what mean , Like when you can fell it thump you in the chest ?? I feel my one little sony 12 that I borrowed from wal mart ( why my tinsel leads are out to adire getting fixed ) more than the Brahma > I know it sounds funny is it just the sub ??
Yeah man. Change the phase and see if it makes a difference. Also if you can try turning the enclosure different ways. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by ramos Yeah man. Change the phase and see if it makes a difference. Also if you can try turning the enclosure different ways. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I have tried everything , Theya re in phase with the front and it sounds the best that way , Anyway the tinsel lead broke off and its sent back to ampman
Originally posted by Spddracer I have tried everything , Theya re in phase with the front and it sounds the best that way , Anyway the tinsel lead broke off and its sent back to ampman
D@mn man, that *****. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Ramos..what would you reccomend for a box in a extended cab F-150 w/a base of 19x19 at most? It's for a Brahma 15", I've tried box designing programs but they never come out right.
166
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
499
370
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
350
645
Spddracer
Sounds Goooooood
Spddracer
Ohio
Jdg784
    May 16, 2024
    May 16, 2024
