RAAMat in hot climates?
Has anyone who lives in an extremely hot climate had any problems with RAAMat? I go to Arizona quite often during the summer where the temperature outside can reach as high as 130 degrees (yes it can get that hot). I'm sure this equates to temperatures around or above 250 degrees inside my door panel.
Thanks.
Thanks.
The only problem I've had with it is the metal backing peeled off a little around the corners of the trunk lid. It's on a black car in East,TN. It's still sticks pretty good after 2 summers.
Well I don't live in Arizona, I just go there a lot during the summer. So if going to put a whole bunch of RAAMat in my doors I don't want to have to worry about it melting.
I saw on that sounddeadeningshowdown.com website that the RAAMat starts failing at 250 degrees. Won't the inside of my doors be hotter than this when it is 120 degrees outside?
I live in Texas and it has been around 100-105, degrees for the past month w/ the heat index. I have a temperature gauge inside my truck and the inside of the truck reaches 130-135. I'm no expert but I doubt the inside of your doors would reach 250 degrees. My RaaMat holds up very well. I still have some exposed on the back wall and I see know signs of failure.
cleanerupper
cleanerupper
Yourmomsville, MO
QtrHorse
