Quick wiring question!
mxer69
So here is the diagram. Question is what do I do about the power and RCA's? Can I jack it off of the 1/0 guage wire from the brutus 1608 amp? I can get my hands on a distribution block. But what about the RCA's? If I can get away with not running another set, that'd be preferable.
I'm putting in my zed 4 channel and some new CDT comps for those who are curious
Diagram:
thats all i read and i am confused
Well wouldn't you want to run two sets of RCA's so that one is outputting your sub and the other is outputting your front/rear?
Right. Do I need to? Also, I only have 5 rca outs on my h/u if I'm not mistaken.. then what?
You're over thinking this, man. 5 outputs is fine. Just get a distro block, a set of 4 channel rca's (along with the 2 channel rca's you already have) and a y-splitter for your sub output...
I really think I am. I can handle the power now. Just confused with the RCA's. I have a set of RCA's hooked up to my mono amp but I'm pretty sure it also has RCA's out. Can I just take the set of RCA's out and split it with a Y splitter for both the left and the right and then hook those (total of 2 sets of RCA cables) to the 4 channel? I'd like to not have to run new RCA's but if it's necessary I can do it..
Just run a set of 4 channel rca's from the hu to the 4 channel amp and buy a distro block. Simple...
Apparently I have 6 rca outputs on the H/U so that makes it easy. Lol thanks for the help misfit
Not a good idea. If your RCA's are plugged into the SUB-OUT of the headunit, then any adjustments for bass/sub gain will go through to your 4-channel amp too. Just run separate front/rear/sub RCA's.
mxer69
mxer69
DC
misfit138
