I think you're either under-powering or over-powering you subs.
I'm guessing you got 2 DVC, 4ohm + 4ohm 12" type E's (swe-1241), you need to match the subs with the proper amp that will not underpower them and is not too powerful, otherwise you must adjust the gain accordingly.
"# Kevlar®-treated pulp cone
# 3/4" Santoprene rubber surround
# dual oversized Nomex® spiders
# frequency response 26-1,000 Hz
# power range 50-200 watts RMS
# peak power handling 600 watts
# sensitivity 89 dB
# top-mount depth 6-3/16"
# sealed box volume: 0.8-1.7 cubic feet
# ported box volume: 1.25-2.0"
You'll need a 8 guage wire (just get an amp wiring kit 20 bucks at walmart) connected to your battery, the on-lead wire (usually blue, connects to the head unit, comes with kit), maybe an aftermarket deck (if not purcashed already, unless the factory deck has the wire you need, you could take the on-lead wire from the factory amp then hook it up to the new one)
...once you got that (for two subs) you'll need an amp that supplies 400 watts RMS @ 2ohms bridged if 2 channels (will be like 800+ watts peak, don't over do it) (100 watts RMS per channel @ 4ohms if 2 channel, then you'll wire your subs at 8 ohms, parallel connect them to the amp, For a 2 channel amp, bridge them, comes out to 2 ohms, power will output to 400 watts rms to both subs, (200 each) with a peak of 800+ to both (400+ each))
The box you got probaly is good.
I looked for an amp that would work for you if you got two dvc 4+4ohms subs
http://www.crutchfield.com/S-CfBHZaQm5bj/cgi-bin/ProdView.asp?g=110&I=037A4002T
Its an audiobahn, pretty good, I'm not kidding either. My experience with them has been great, and they'll power those type E's EZ
Key Features:
» 100 watts RMS x 2 at 4 ohms
» 200 watts RMS x 2 at 2 ohms
» 400 watts RMS x 1 bridged output
» stereo or bridged mono output
» Tri-way capable (Tri-Way Crossover required)
» MOSFET power supply
» requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
» 40-amp fuse
» 50-750 Hz high-pass/50-120 Hz low-pass crossover, 18 dB/octave
» 18 dB bass boost at 50 Hz (switchable on/off)
» variable (20-50 Hz) subsonic filter
» preamp outputs
» cooling fan
» cobalt blue illumination
» speaker- and preamp-level inputs
» 11-5/16"W x 2-3/8"H x 10-7/8"D
This amp is perfect for you, get it at
crutchfield (comes with 1-year warrenty) for 200$, or you can get it cheaper maybe for like 120$ if you look hard enough on
ebay.
Heres a wiring diagram that you can use:
on a bridged two channel amp the ohm dependence will drop to 2, and will power 200 watts rms to each sub. (peak 400+watts)
there is a difference between RMS watts, and Peak watts, RMS is constant power, peak is well, peak, only lastly for a moment, sometimes referred as fake watts.
//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
I think this is enough info.
