quick question
carlos18
i just picked up a t10001bd amp, and 2 type-r 12's(dvc-2ohms). i am still kinda new to this. i was going to bridge them and wire them at a 2ohm load. as i was reading the owners manual for the amp, it said its not recommended to do a 2ohms brige. will the amp be ok?
has anybody had problems with this amp at a 2ohm bridge?
thanks
well it says."Caution:these amplifiers are not recommended for impendance below 1ohm or 2ohm per bridged (strapped) amplifier pairs.
what does that mean? can it take a 2ohm bridge?
You will be fine running that amp at 2 ohms since it is actually one ohm stable. What it means by bridging is two amplifiers bridged together and even then you would be able to do 2 ohm just not below 2 ohm.
carlos18
carlos18
texas
mokedaddy
vegang
vegang
