Quick Question with Alt. Wire
forceofwill
Ok, i'm in the process of doing my big three with 1/0. My alternator-battery wire goes from the alt to the fusebox, then out and to the battery. So i'm leaving that alone and just adding a 1/0 from the alt to the battery. My question is since the 1/0 goes straight to the battery and is of a much bigger gauge, will the current all go through this wire and cause problems because the original wire isn't getting current to the fuse box? Or am I retarded and they will both be fed equally. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
How's the big 3 coming along? I was doing mine today, but can't get the bolt off the alternator that holds the cable //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif None of my sockets will fit between my alternator and my a/c lines, and i don't want to drive the car till it's done...
I even made my own 'tool' with a 13mm socket, and an allen wrench.
Tomorrow i'll get a universal, hopefully you're having more luck!
forceofwill
forceofwill
Chesapeake, VA
yacob.naif
