Brometheus
So my system was cutting off so i decided to check it out.
One of the screws that pinch the speaker wire came loose leaving the power wire free.
Cant find the little screw and was wondering if i could use something else to screw on.
Its one of those screws on the terminal post of the enclosure. One for negative and one for positive. The positive one came off. Basically you put the stripped end of the speaker wire on the post and then use the screw to tighten it down.
Where can i get a replacement or i can use anything that would basically screw in?
